Ce dont vous avez besoin
Retournez l’ordinateur portable de sorte que la partie inférieure du boîtier soit face à vous.
Placez votre pouce gauche sur le loquet de déverrouillage de la batterie.
Placez votre pouce droit sur le loquet d’éjection de la batterie.
Utilisez un tournevis à tête cruciforme n° 00 pour retirer les vis de 8 mm de la bande du clavier situé sous la batterie.
Pour remonter votre appareil, suivez ces instructions dans l’ordre inverse.
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Brendan nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Wow, so I was about to call BS on this being a weirdly convoluted way to do this, but instead I learned something. In the pictures you can see a panel, right above the Windows Authenticity sticker, with a black "CAUTION" sticker held in by a single screw. Remove this panel and, voila, there's your RAM slot. I kept wondering why the author of this guide was having the reader go to all the trouble of removing the keyboard when obviously you could access this area from this spot on the bottom a whole lot easier.
Well, guess what? Contrary to my initial belief, this is NOT just a more convoluted method of reaching the same slot! So yeah, it's probably worth mentioning that there are actually 2 slots in different locations for anyone else who may be screwing around with this ancient laptop and be as confused as I was for a second there. (I suspect the author just forgot to mention it, since you can see they've removed that back panel stick already in the Step 4 pic.)
