Introduction
This guide will show you the steps required to remove your charging port.
Pièces
Aucune pièce nécessaire.
Make sure the lock switch for the back cover is unlocked.
  • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Ajouter un commentaire
Remove back cover by prying away from the Thrive.
  • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
  • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  • Carefully open the device like a book and lay the two halves beside each other.
Can you add a picture of somebody opening the device?
Dan Brown - Réponse
  • Remove the two screws holding the charging port in place. The screws are 3mm in length and require a PH0 screwdriver.
    • Using a pair of tweezers, lift up the charging port's protective covering
  • Use the tweezers to pull out the connector connecting the charging port to the motherboard.
  • Using the tweezers again, gently lift up the charging port from your Thrive.
3 autre(s) ont terminé cette réparation.
Kason
Membre depuis le 22/09/2014
945 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 10-1, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 membres
6 tutoriels rédigés
I added "better pictures" flag because i was having trouble following the last step cause i couldnt see anything.
Sun Fai Lau - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 26
Total : 3,296
