Introduction
This guide will show you how to replace the speakers in your Toshiba Thrive.
Make sure the lock switch for the back cover is unlocked.
  • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Ajouter un commentaire
Remove back cover by prying away from the Thrive.
  • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  • Start by using a PH0 phillips head screwdriver to remove the 12 screws holding on the back cover
    • All of these screws are identical so don't worry about getting them mixed up.
  • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  • carefully open the device like a book and lay the two halves beside each other.
  • put the screen assembly in a safe place as you complete the rest of the guide.
  • Use the plastic opening tool to open the latch holding the last wire to the back of the device.
this is the step you need on the other step i commented on
Sun Fai Lau - Réponse
  • Remove the two screws holding the speakers in place. The screws are 3mm in length and require a PH0 screwdriver.
  • Using a pair of tweezers, remove the speaker.
  • Use the tweezers to help you remove the speaker wire from the clips holding them in place.
  • After removal place the left speaker on the side.
  • Use the tweezers again to help you remove the right speaker from its position.
  • Use a plastic opening tool to pull the connector connecting the speaker to the motherboard out of its port.
Ivan Williams
Membre depuis le 22/09/2014
127 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 10-1, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 230
