Aller au contenu principal
TotalPond Pond Pump Impeller Replacement
  1. TotalPond Pond Pump Impeller Replacement, Impeller: étape 1, image 1 de 1
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Replacement: étape 2, image 1 de 1
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Replacement: étape 3, image 1 de 2 TotalPond Pond Pump Impeller Replacement: étape 3, image 2 de 2
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
  4. TotalPond Pond Pump Impeller Replacement: étape 4, image 1 de 2 TotalPond Pond Pump Impeller Replacement: étape 4, image 2 de 2
    • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
2 autres ont terminé cette réparation.
Nicole Santana
Membre depuis le 01/13/15
597 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 3-6, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-6, Hickman Winter 2015
USFT-HICKMAN-W15S3G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 39
Total : 3,227
