Aller au contenu principal
TotalPond Pond Pump Impeller Spindle Replacement
  1. TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: étape 1, image 1 de 3 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: étape 1, image 2 de 3 TotalPond Pond Pump Impeller Spindle Replacement, Impeller Spindle: étape 1, image 3 de 3
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Spindle Replacement: étape 2, image 1 de 3 TotalPond Pond Pump Impeller Spindle Replacement: étape 2, image 2 de 3 TotalPond Pond Pump Impeller Spindle Replacement: étape 2, image 3 de 3
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Spindle Replacement: étape 3, image 1 de 2 TotalPond Pond Pump Impeller Spindle Replacement: étape 3, image 2 de 2
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller. Also remove the bearing that is between the stop and the impeller.
  4. TotalPond Pond Pump Impeller Spindle Replacement: étape 4, image 1 de 2 TotalPond Pond Pump Impeller Spindle Replacement: étape 4, image 2 de 2
    • Hold the impeller cover with one hand and the impeller with the other. Slide the impeller out.
  5. TotalPond Pond Pump Impeller Spindle Replacement: étape 5, image 1 de 2 TotalPond Pond Pump Impeller Spindle Replacement: étape 5, image 2 de 2
    • Hold the impeller spindle and wiggle it side to side until it detaches from the impeller cover.
Nicole Santana
Membre depuis le 01/13/15
597 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 3-6, Hickman Winter 2015 Membre de l'équipe USF Tampa, Team 3-6, Hickman Winter 2015
USFT-HICKMAN-W15S3G6
4 membres
5 tutoriels rédigés
Un commentaire
The part number of the spindle itself would probably be a good idea to included in this guide.
rz22g - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 1,356
