Aller au contenu principal
Toy Lightsaber Battery Replacement
Ce dont vous avez besoin
  1. Toy Lightsaber Battery Replacement, Battery: étape 1, image 1 de 3 Toy Lightsaber Battery Replacement, Battery: étape 1, image 2 de 3 Toy Lightsaber Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: étape 2, image 1 de 3 Toy Lightsaber Battery Replacement: étape 2, image 2 de 3 Toy Lightsaber Battery Replacement: étape 2, image 3 de 3
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: étape 3, image 1 de 3 Toy Lightsaber Battery Replacement: étape 3, image 2 de 3 Toy Lightsaber Battery Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: étape 4, image 1 de 3 Toy Lightsaber Battery Replacement: étape 4, image 2 de 3 Toy Lightsaber Battery Replacement: étape 4, image 3 de 3
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: étape 5, image 1 de 3 Toy Lightsaber Battery Replacement: étape 5, image 2 de 3 Toy Lightsaber Battery Replacement: étape 5, image 3 de 3
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: étape 6, image 1 de 3 Toy Lightsaber Battery Replacement: étape 6, image 2 de 3 Toy Lightsaber Battery Replacement: étape 6, image 3 de 3
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
Zachary Adaes
Membre depuis le 03/22/21
133 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S3-G1, Saloman Spring 2021 Membre de l'équipe UMass Dartmouth, Team S3-G1, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G1
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 74
Total : 3,785
