Introduction
This is a guide on how to replace a 2009 Toyota Sienna headlight. The only part you need is a replacement lightbulb, which can be found at any local auto store. This repair is needed since blown out lightbulbs is a very common issue in cars. Doing the replacement yourself can save you money compared to taking your vehicle to a mechanic. However, making mistakes or damaging parts due to lack of guidance can end up costing you more in the long run. A guide helps you avoid costly errors.
Ce dont vous avez besoin
Locate the latch on the bottom left of steering wheel.
Once found, pull in your direction.
