Aller au contenu principal
Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement
Ce dont vous avez besoin
  1. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: étape 1, image 1 de 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: étape 1, image 2 de 2
    • Remove the Torx-head screws (23.2mm) on the inside panel of the tailgate, using the torx T25 screwdriver.
  2. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 2, image 1 de 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 2, image 2 de 2
    • Pull off the panel and then pull cables inward, causing tailgate to release and go down.
  3. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 3, image 1 de 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 3, image 2 de 2
    • Remove rubber pieces from cable and pull cable from insert.
  4. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 4, image 1 de 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 4, image 2 de 2
    • Use your 5/16th-in. wrench to turn bolt counter clockwise and remove the bolts (18.5mm).
  5. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 5, image 1 de 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 5, image 2 de 2
    • Push in black clip to let handle fall out.
  6. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 6, image 1 de 1
    • Put new tailgate handle back in.
  7. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 7, image 1 de 1
    • Hand twist in bolts; then tighten with wrench.
  8. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 8, image 1 de 1
    • Insert cable back into socket and press rubber lock onto cable.
  9. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: étape 9, image 1 de 1
    • Put panel back into place and screw in using your torx -T25 screwdriver.
This Device is a medium hardness fix but, with hard-work it can be achieved in only about 30 minutes
Brandon Gibson
Membre depuis le 03/26/20
169 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
You skipped the problematic part about changing the lock.
Declan Haptism - Réponse
I’m about to replace my handle.. I also need the 4 white clips that help align the latch rods. Mine were old brittle and all broken. Any chance you have a part number for those small clips?
Ryan Rodriguez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 46
30 derniers jours : 161
Total : 10,381
