Aller au contenu principal
Toyota bB (first gen) Oil and filter change
Ce dont vous avez besoin
  1. Toyota bB (first gen) Oil and filter change, Lift the car: étape 1, image 1 de 3 Toyota bB (first gen) Oil and filter change, Lift the car: étape 1, image 2 de 3 Toyota bB (first gen) Oil and filter change, Lift the car: étape 1, image 3 de 3
    • This car has no easy lifting points, and a bodykit and low ground clearance makes lifting a bit harder
    • I was able to come in from behind the front wheels at the sides and lift from the box section of the unibody as pictured
    • The jack-stands I placed hard up against the jack and found a spot on the "frame-rails" (box section of unibody)
  2. Toyota bB (first gen) Oil and filter change, Get under the car: étape 2, image 1 de 2 Toyota bB (first gen) Oil and filter change, Get under the car: étape 2, image 2 de 2
    • I like to use cardboard, but a shop creeper would work too
    • The oilpan and drain bolt are located at the right-front of the car
  3. Toyota bB (first gen) Oil and filter change, Identify the targets: étape 3, image 1 de 1
    • The oil filter is faced downwards and is just in front of the oil pan under the intake manifold
    • You don't need to take off the plastic under-shield but if it's annoying you could
  4. Toyota bB (first gen) Oil and filter change, Drain the oil: étape 4, image 1 de 2 Toyota bB (first gen) Oil and filter change, Drain the oil: étape 4, image 2 de 2
    • The drain bolt on the 1.3L engine is a 14mm
    • Re-position the pan as it drains - especially if it's a windy day
  5. Toyota bB (first gen) Oil and filter change, Remove old oil filter: étape 5, image 1 de 2 Toyota bB (first gen) Oil and filter change, Remove old oil filter: étape 5, image 2 de 2
    • I like to use a set of oil-filter pliers but a correct oil filter socket would be a luxury, or a strap wrench or other tool would be fine
    • Make SURE the gasket comes off with the old filter and is NOT stuck on the block
  6. Toyota bB (first gen) Oil and filter change, Install new filter and drain bolt: étape 6, image 1 de 3 Toyota bB (first gen) Oil and filter change, Install new filter and drain bolt: étape 6, image 2 de 3 Toyota bB (first gen) Oil and filter change, Install new filter and drain bolt: étape 6, image 3 de 3
    • Oil up your new filter's gasket
    • Since the oil filter is facing down, you can pre-fill the oil filter if you like, it can be messy if you drop it though!
    • Clean the mating surface with rags before installing the new filter
    • Tighten the filter 3/4 turn after it touches the block
    • Remember to also tighten the oil drain bolt, and clean around each area with rags so you can spot leaks easier
  7. Toyota bB (first gen) Oil and filter change, Lower the car: étape 7, image 1 de 1
    • Remove cardboard/creeper and any tools
    • Lift each side and remove the jack stand
    • Lower the car which will level it for filling
    • The fill cap and dipstick are located at the front-right of the car (left side of engine bay)
    • I used 10W-40 full synthetic oil, and the car accepted around 3.8L
    • I like to use a stubby wide-mouth funnel
    • Sorry I didn't take any photos of this step as it was the end of a long day of 3x cars servicing
    • Run the car for 15 seconds or so to fill the filter and oil galleries
    • Turn off the car and check for leaks underneath
    • Check the level again with the dipstick and top up as required
Servicing Done!
2 autres ont terminé cette réparation.
Gaspard Leon
Membre depuis le 04/24/10
2 801 Réputation
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 21
Total : 3,015
