Aller au contenu principal
Traxxas Summit Steering Assembly Servo Replacement
Ce dont vous avez besoin
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: étape 1, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: étape 1, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: étape 1, image 3 de 3
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: étape 2, image 1 de 2 Traxxas Summit Steering Assembly Servo Replacement: étape 2, image 2 de 2
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: étape 3, image 1 de 2 Traxxas Summit Steering Assembly Servo Replacement: étape 3, image 2 de 2
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: étape 4, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 4, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 4, image 3 de 3
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: étape 5, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 5, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 5, image 3 de 3
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: étape 6, image 1 de 2 Traxxas Summit Steering Assembly Servo Replacement: étape 6, image 2 de 2
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: étape 7, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 7, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 7, image 3 de 3
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: étape 8, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 8, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 8, image 3 de 3
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: étape 9, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 9, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 9, image 3 de 3
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: étape 10, image 1 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 10, image 2 de 3 Traxxas Summit Steering Assembly Servo Replacement: étape 10, image 3 de 3
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
Carson J. Bailey
Membre depuis le 02/28/17
117 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 29
Total : 2,320
