Introduction
This guide gives simple directions on how to replace the front derailleur cable, an important component that is easy to replace. The derailleur is the part of the bike that allows a rider to quickly shift gears while riding. Most bikes have two, one in the front and one in the back. This guide deals only with the front one. A broken or overly frayed derailleur cable can cause the derailleur to misalign, create difficulty shifting, or prevent the chain from going on any of the sprockets (gears).
Ce dont vous avez besoin
Use the Allen wrench to loosen the Allen bolt that keeps the derailleur cable in tension and attached to the derailleur body.
Check the derailleur placement.
The chain should be roughly centered in the derailleur, so that no extra friction is caused, and that the chain is not unintentionally pushed off the sprocket.
If not in the correct position, reloosen the tightening bolt and redo step 13. This may take several tries.
Before putting away the tools, test the alignment of the derailleur by shifting between the gears while pedaling the bike to make sure it smoothly and easily changes gears. If not, the tightening bolt can be readjusted until it is properly adjusted. Also look into the derailleur adjustment screws on the top of the derailleur for fine adjustment if desired.
6 autres ont terminé cette réparation.
2 commentaires
The above is very helpful, however my shift lever is part of the handle bar. I just rotate my hand to shift. How do I get into this shift to get to
the cable?
Hey, this was awesome…. I have the same color Trek 4300 and the bike is in similar condition, i’m repairing the rear derailleur cable now… Cheers!! Manish - India
