Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to remove the front wheel off your Trek 820 mountain bike.
  1. Facing your bike, straddle your front wheel between your knees. Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
    • Facing your bike, straddle your front wheel between your knees.
    • Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
    • Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
  2. With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand. The brake will now be open wide enough to permit removal of the wheel.
    • With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand.
    • The brake will now be open wide enough to permit removal of the wheel.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Find the quick release lever on the outside of the bike's fork on the right hand side. Turn the level counter clockwise loosening the lever until it comes off. Find the quick release lever on the outside of the bike's fork on the right hand side. Turn the level counter clockwise loosening the lever until it comes off.
    • Find the quick release lever on the outside of the bike's fork on the right hand side. Turn the level counter clockwise loosening the lever until it comes off.
  5. After the quick release lever is removed, the wheel can be separated from the front fork.
    • After the quick release lever is removed, the wheel can be separated from the front fork.
    • In reassembling the wheel to the bike, perform the steps in reverse order.
    • With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
    • Squeeze the brake calipers together and return the cable noodle back into the holder.
    • Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
3 autre(s) ont terminé cette réparation.
Kaveh Karimiyanha
Membre depuis le 24/09/2012
777 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-1, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 28
30 derniers jours : 119
Total : 9,300
