Aller au contenu principal
Trek 820 Light Mount Replacement
Ce dont vous avez besoin
  1. Trek 820 Light Mount Replacement, Light Mount: étape 1, image 1 de 2 Trek 820 Light Mount Replacement, Light Mount: étape 1, image 2 de 2
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: étape 2, image 1 de 1
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: étape 3, image 1 de 1
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: étape 4, image 1 de 1
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: étape 5, image 1 de 2 Trek 820 Light Mount Replacement: étape 5, image 2 de 2
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
Now you have a light mount ready for safer night rides on your Trek bicycle!
Kaveh Karimiyanha
Membre depuis le 09/24/12
813 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-1, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 856
