Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Outils
Pièces
Aucune pièce spécifiée.
  1. You will need the 7/16" wrench for this. Lock the wrench to the pedal and carefully unscrew it until the pedal comes off. Lock the wrench to the pedal and carefully unscrew it until the pedal comes off.
    • You will need the 7/16" wrench for this.
    • Lock the wrench to the pedal and carefully unscrew it until the pedal comes off.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. Once the old pedal is off, you may replace it with a new pedal. Once the old pedal is off, you may replace it with a new pedal. Once the old pedal is off, you may replace it with a new pedal.
    • Once the old pedal is off, you may replace it with a new pedal.
Kaveh Karimiyanha
Membre depuis le 24/09/2012
777 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-1, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 2,242
