Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Trek 820 Tail Light Mounting Bracket Replacement
Ce dont vous avez besoin
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: étape 1, image 1 de 1
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: étape 2, image 1 de 1
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: étape 3, image 1 de 2 Trek 820 Tail Light Mounting Bracket Replacement: étape 3, image 2 de 2
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: étape 4, image 1 de 2 Trek 820 Tail Light Mounting Bracket Replacement: étape 4, image 2 de 2
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Kaveh Karimiyanha
Membre depuis le 09/24/12
813 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-1, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 membres
9 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 88
Total : 1,393
