Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Outils
Aucun outil spécifié.
  1. Obtain one tail light mounting bracket and one screw as shown in the picture.
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Clean the bicycle seat post and mounting bracket.
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Locate the slot on the bracket where the strap will be inserted. Insert the strap into the slot.
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  5. Insert the screw into the bracket screw hole. Tighten the screw with fingers until the mounting bracket rests freely on seat post.
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Kaveh Karimiyanha
Membre depuis le 24/09/2012
777 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 1-1, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 999
