Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Trek FX2 Fitness Bike Saddle Replacement
Ce dont vous avez besoin
  1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: étape 1, image 1 de 3 Trek FX2 Fitness Bike Saddle Replacement, Saddle: étape 1, image 2 de 3 Trek FX2 Fitness Bike Saddle Replacement, Saddle: étape 1, image 3 de 3
    • Locate the bolt under the saddle.
    • Use a 5mm Allen Wrench to loosen and remove the M8x30 mm bolt.
    • Remove the saddle from under the plate.
  2. Trek FX2 Fitness Bike Saddle Replacement: étape 2, image 1 de 2 Trek FX2 Fitness Bike Saddle Replacement: étape 2, image 2 de 2
    • Use a towel covered in isopropyl rubbing alcohol to clean any dirt from the bolts and plate.
  3. Trek FX2 Fitness Bike Saddle Replacement: étape 3, image 1 de 2 Trek FX2 Fitness Bike Saddle Replacement: étape 3, image 2 de 2
    • Apply Finish Line Premium Grease to the bolt.
    • Work the grease around the threads.
  4. Trek FX2 Fitness Bike Saddle Replacement: étape 4, image 1 de 3 Trek FX2 Fitness Bike Saddle Replacement: étape 4, image 2 de 3 Trek FX2 Fitness Bike Saddle Replacement: étape 4, image 3 de 3
    • Clean the replacement bicycle saddle with a towel and isopropyl alcohol.
  5. Trek FX2 Fitness Bike Saddle Replacement: étape 5, image 1 de 2 Trek FX2 Fitness Bike Saddle Replacement: étape 5, image 2 de 2
    • Apply Finish Line Premium Grease to the rails of the bicycle saddle.
  6. Trek FX2 Fitness Bike Saddle Replacement: étape 6, image 1 de 3 Trek FX2 Fitness Bike Saddle Replacement: étape 6, image 2 de 3 Trek FX2 Fitness Bike Saddle Replacement: étape 6, image 3 de 3
    • Align the seat rails with the channels in the saddle plate.
    • Slide the rails into the channels of the saddle plate.
    • Adjust the seat position to your preference.
  7. Trek FX2 Fitness Bike Saddle Replacement: étape 7, image 1 de 3 Trek FX2 Fitness Bike Saddle Replacement: étape 7, image 2 de 3 Trek FX2 Fitness Bike Saddle Replacement: étape 7, image 3 de 3
    • Insert the bolts into the holes on the saddle plate.
    • Tighten the bolts by hand until they are snug.
    • Use an Allen wrench to evenly tighten the bolts.
  8. Trek FX2 Fitness Bike Saddle Replacement: étape 8, image 1 de 1
    • Sit on the seat to check its angle and stability.
Test out the bike seat, and adjust accordingly.
David Fong
Membre depuis le 11/05/24
157 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 Membre de l'équipe UC Davis, Team 4-6, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G6
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 23
30 derniers jours : 102
Total : 890
