Aller au contenu principal
Trek Neko Bike Brake Pad Replacement
Ce dont vous avez besoin
  1. Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: étape 1, image 1 de 2 Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: étape 1, image 2 de 2
    • Squeeze the two brake arms together.
    • Angle the brake noodle down.
    • Push the quick release down to release the brake noodle.
  2. Trek Neko Bike Brake Pad Replacement: étape 2, image 1 de 1
    • Flip the bike over so that the seat is on the ground.
  3. Trek Neko Bike Brake Pad Replacement: étape 3, image 1 de 3 Trek Neko Bike Brake Pad Replacement: étape 3, image 2 de 3 Trek Neko Bike Brake Pad Replacement: étape 3, image 3 de 3
    • Open the quick release lever on the bike wheel.
    • Rotate the lever in a counter clockwise direction to loosen the wheel.
    • Remove the wheel from the bike frame.
  4. Trek Neko Bike Brake Pad Replacement: étape 4, image 1 de 2 Trek Neko Bike Brake Pad Replacement: étape 4, image 2 de 2
    • Loosen the locking bolt on the brake pad with a 5 mm Allen wrench.
    • Remove the locking bolt, washers, and brake pad from the brake pad housing.
  5. Trek Neko Bike Brake Pad Replacement: étape 5, image 1 de 2 Trek Neko Bike Brake Pad Replacement: étape 5, image 2 de 2
    • Insert the new brake pad.
    • Insert the washers.
    • Insert the locking bolt.
  6. Trek Neko Bike Brake Pad Replacement: étape 6, image 1 de 2 Trek Neko Bike Brake Pad Replacement: étape 6, image 2 de 2
    • Tighten the brake pad locking bolt bolt clockwise until it is finger tight.
    • Tighten the bolt with a 5 mm Allen wrench.
  7. Trek Neko Bike Brake Pad Replacement: étape 7, image 1 de 3 Trek Neko Bike Brake Pad Replacement: étape 7, image 2 de 3 Trek Neko Bike Brake Pad Replacement: étape 7, image 3 de 3
    • Reinsert the wheel.
    • Tighten the bolt on the wheel until it is finger tight.
    • Center the wheel in the frame.
    • Close the quick release lever to secure the wheel.
  8. Trek Neko Bike Brake Pad Replacement: étape 8, image 1 de 2 Trek Neko Bike Brake Pad Replacement: étape 8, image 2 de 2
    • Place the bike right side up.
  9. Trek Neko Bike Brake Pad Replacement: étape 9, image 1 de 3 Trek Neko Bike Brake Pad Replacement: étape 9, image 2 de 3 Trek Neko Bike Brake Pad Replacement: étape 9, image 3 de 3
    • Insert the brake noodle into the quick release lever.
    • Angle the quick release lever upwards so that the brake noodle clicks into place.
  10. Trek Neko Bike Brake Pad Replacement: étape 10, image 1 de 2 Trek Neko Bike Brake Pad Replacement: étape 10, image 2 de 2
    • Squeeze the brakes to check proper fitment.
    • Tighten or loosen the quick release bolt on the brake arms to adjust based on preference.
With properly installed brake pads, you can now safely ride your bike!
2 autres ont terminé cette réparation.
Camille Nikaido
Membre depuis le 02/02/23
181 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-9, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 1-9, Andersen Winter 2023
UCD-ANDERSEN-W23S1G9
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 38
Total : 818
