Aller au contenu principal
Tribit XSound Go TS-BTS20 Passive Radiator Replacement
Ce dont vous avez besoin
  1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: étape 1, image 1 de 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: étape 1, image 2 de 2
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: étape 2, image 1 de 1
    • Unscrew all the screws with the Phillips screwdriver, on the opened panel.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: étape 3, image 1 de 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement: étape 3, image 2 de 2
    • Hold the frame which has the passive radiator in the middle.
  4. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: étape 4, image 1 de 1
    • Use a spudger to push the damaged passive radiator off the frame
  5. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: étape 5, image 1 de 1
    • Insert the new passive radiator into the frame.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
Hasini Kanuru
Membre depuis le 09/12/23
271 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 193
