Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will describe how to remove the back cover to your Trio STEALTH-9 and replace a new one in its place. This process should not take too long and will only require the removal of a few screws and a careful hand with the plastic shell.
  1. Remove the two Phillips #00 screws on the side of the tablet.
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  4. Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  5. Remove the back cover of the tablet to reveal the internals.
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
To reassemble your device, follow these instructions in reverse order with your replacement cover!
2 autre(s) ont terminé cette réparation.
Mei Liang
Membre depuis le 29/01/2015
228 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 15-5, Shirley Winter 2015 Membre de l'équipe Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
5 membres
10 tutoriels rédigés
Tengo.una y costo tiene el.displey
eliehtmaria - Réponse
Deseo.saber el.c
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,020
