Aller au contenu principal
Tristar Handmixer Gears Replacement
Ce dont vous avez besoin
  1. Tristar Handmixer Gears Replacement, Gears: étape 1, image 1 de 3 Tristar Handmixer Gears Replacement, Gears: étape 1, image 2 de 3 Tristar Handmixer Gears Replacement, Gears: étape 1, image 3 de 3
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: étape 2, image 1 de 3 Tristar Handmixer Gears Replacement: étape 2, image 2 de 3 Tristar Handmixer Gears Replacement: étape 2, image 3 de 3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: étape 3, image 1 de 3 Tristar Handmixer Gears Replacement: étape 3, image 2 de 3 Tristar Handmixer Gears Replacement: étape 3, image 3 de 3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: étape 4, image 1 de 2 Tristar Handmixer Gears Replacement: étape 4, image 2 de 2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: étape 5, image 1 de 1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
njjong
Membre depuis le 12/05/16
25 Réputation
1 tutoriel rédigé
2 commentaires
where can I get replacement gears from?
lanz - Réponse
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 13
30 derniers jours : 40
Total : 1,476
