Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tristar Handmixer Gears Replacement
Ce dont vous avez besoin
  1. Tristar Handmixer Gears Replacement, Gears: étape 1, image 1 de 3 Tristar Handmixer Gears Replacement, Gears: étape 1, image 2 de 3 Tristar Handmixer Gears Replacement, Gears: étape 1, image 3 de 3
    • Remove all the screws with the spanner and Phillips screwdrivers.
    Demander à FixBot
    Ajouter un commentaire
  2. Tristar Handmixer Gears Replacement: étape 2, image 1 de 3 Tristar Handmixer Gears Replacement: étape 2, image 2 de 3 Tristar Handmixer Gears Replacement: étape 2, image 3 de 3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
    Demander à FixBot
  3. Tristar Handmixer Gears Replacement: étape 3, image 1 de 3 Tristar Handmixer Gears Replacement: étape 3, image 2 de 3 Tristar Handmixer Gears Replacement: étape 3, image 3 de 3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
    Demander à FixBot
  4. Tristar Handmixer Gears Replacement: étape 4, image 1 de 2 Tristar Handmixer Gears Replacement: étape 4, image 2 de 2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
    Demander à FixBot
  5. Tristar Handmixer Gears Replacement: étape 5, image 1 de 1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
    Demander à FixBot
2 autres ont terminé cette réparation.
njjong
Membre depuis le 12/05/16
49 Réputation
1 tutoriel rédigé
3 commentaires de tutoriel
where can I get replacement gears from?
lanz - Réponse Partager
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz - Réponse Partager
On it now. Let's hope we don't need to buy Cheap-China-plastic. Ideal of course would be to find metal gears, that would last whole life (if not motor breaks).
I also need to find a manufacturer of cog drive train wheels, that could do custom made, tailored, because if you refurbish a vintage handmixer you need parts that are not manufactured or in circulation anymore.
Henry - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 73
Total : 2,667
