Introduction
This LED strip gives your truck a more kickass appearance to complete the look. It's not every day that you see trucks with some pretty neat LED strip lights so be the first one on the road to have LED tailgate strip lamps! These are LED tail gate strip lights with 4 functions: on/off brake mode, left turn signal, right turn signal, and reverse mode. These LED strip lights are universal fit so you don't have to worry about compatibility issues.
Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
  • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
  • Use soap and water to scrub the area clean since that place is normally dirty.
Ajouter un commentaire
Carefully measure beforehand where you're going to attach the LED strip so it looks even.
  • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
  • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
  • Straighten the LED strip and peel adhesive.
  • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
  • Tap reverse light wire.
  • You will need to remove either side of the tail light to locate the reverse light.
  • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
  • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
  • You will find the trailer light connector near the tow hitch.
  • Hide the wires or zip-tie them.
  • Check the trunk LED tailgate lamp to make sure everything works.
I don't suppose you could tell me why the reverse lights and brake lights light up at the same time in the reverse gear? Assuming it's something in the wiring in my truck cuz i just put a new 7 blade/ 4 pin harness in it
Cashmere - Réponse
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
3 autre(s) ont terminé cette réparation.
Eric Wu
Membre depuis le 21/01/2015
2 316 Réputation
23 tutoriels rédigés
11 commentaires
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - Réponse
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 -
I'm having the same problem!
Richie - Réponse
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - Réponse
I install led tailgate strip on my 2015 f150 now reverse sensers don't work
ibarraj1975 - Réponse
I install led tailgate strip on my 2015 f150 now reverse sensers don't work and backup camera show like i have trailer connect its totally different any idea how to use the strip and revers camera gonna be work like before? Please any idea mirekdm@yahoo.com
mireklidia - Réponse
I install the led tailgate strip on my 2006 Chevrolet 1500 and i wired the ground and brake wire in first and it worked perfectly fine, when i wired the left turn signal in as well it worked perfectly fine, after i installed the right turn signal wire the brake light part quit working. Any ideas? My email is chelseamoore1972@gmail.com
Chelsea Moore - Réponse
just go a head and cancel my order
Paul Knight - Réponse
Any f150 owners out there go to opt7 and get their tailgate module. It will make your tail light bar work. I had the same issues with the trailer stuff going on. It's the way Ford wired everything. I have been searching for almost a year to figure it out. I'll be taking the strip I wired onto my truck off this weekend and putting a new strip on from opt7 and their module. They told me this will fix everything. I will repost after doing this and let everyone know how it worked. I bought their 3 row 1200 led strip which is supposed to be the brightest out there. Also if any f150 owners want to upgrade their lighting go to www.f150leds.com. I have bought headlights and other bulbs from them and they are the best and brightest…
Good luck.
John Tynan - Réponse
I put my led strip on and during the day I can set cruise and start the truck automatically but at night when the led stripe is on I can’t do anything bc it says my brakes are being pushed while I am driving my Silverado 1500
anyone know what is doing this at night time y is it saying brakes are on? Thank u in advance
Travis Engard - Réponse
Wondering why when the headlights are on the turn signals on the light bar dont work.
Vwc - Réponse
Voir les statistiques:
Dernières 24 heures : 9
7 derniers jours : 94
30 derniers jours : 544
Total : 18,695
