Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This is a repair guide for battery replacement.
  1. To reach the battery, follow steps 1 through 3 in the Tungsten E Teardown
  2. Begin to pry up the battery.  It is fastened to the mother board using two sided tape.
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. Remove the battery
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  5. Using a soldering iron, disconnect the battery wires.
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  6. Take replacement battery and solder the wires to the board.
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
Kathleen Hix
Membre depuis le 21/01/2010
49 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-22, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 5,861
