Aller au contenu principal
Turtle Beach Ear Force P11 Microphone Replacement
Ce dont vous avez besoin
  1. Turtle Beach Ear Force P11 Microphone Replacement, Microphone: étape 1, image 1 de 1
    • Remove the microphone cover by unscrewing the screw on the front side of the microphone.
    • It is recommended to use #000 Philips head screwdriver.
  2. Turtle Beach Ear Force P11 Microphone Replacement: étape 2, image 1 de 1
    • Use a nylon or metal spudger set to lift out the microphone.
    • Be careful lest you might break the fragile wires.
    • Always try using a plastic tool before resorting to a metal tool as shown in the picture.
  3. Turtle Beach Ear Force P11 Microphone Replacement: étape 3, image 1 de 1
    • De-solder the microphone wires and remove the microphone.
    • Use low heat for de - soldering
    • Do not cut the white and black wires soldered to the microphone as you might reduce the length of wire required to reassemble.
  4. Turtle Beach Ear Force P11 Microphone Replacement: étape 4, image 1 de 1
    • Solder the new microphone wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • You can find more information on How to Solder here: Comment souder et dessouder des connexions
    • To complete reassembly replace the cover taken off in step 1.
Bhavesh Gandhi
Membre depuis le 09/26/15
585 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Wilson Fall 2015 Membre de l'équipe IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,029
