Aller au contenu principal
Turtle Beach Ear Force P11 Speakers Replacement
Ce dont vous avez besoin
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: étape 1, image 1 de 1
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: étape 2, image 1 de 1
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: étape 3, image 1 de 1
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: étape 4, image 1 de 2 Turtle Beach Ear Force P11 Speakers Replacement: étape 4, image 2 de 2
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: étape 5, image 1 de 1
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: étape 6, image 1 de 1
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:Comment souder et dessouder des connexions
4 autres ont terminé cette réparation.
Bhavesh Gandhi
Membre depuis le 09/26/15
585 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Wilson Fall 2015 Membre de l'équipe IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
2 membres
6 tutoriels rédigés
6 commentaires
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - Réponse
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - Réponse
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - Réponse
Do you know where I can get the speakers from?
James Patrick - Réponse
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 20
Total : 3,722
