Aller au contenu principal
Turtle Beach Ear Force Stealth 500P Battery Replacement
Ce dont vous avez besoin
  1. Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: étape 1, image 1 de 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: étape 1, image 2 de 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: étape 1, image 3 de 3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 2, image 1 de 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: étape 3, image 1 de 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: étape 3, image 2 de 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: étape 3, image 3 de 3
    • Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
  4. Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 4, image 1 de 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 4, image 2 de 2
    • Use bent tweezers to remove two wire connector plugs from circuit board.
  5. Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 5, image 1 de 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 5, image 2 de 2
    • Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
  6. Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 6, image 1 de 1
    • Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
  7. Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 7, image 1 de 1
    • Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
  8. Turtle Beach Ear Force Stealth 500P Battery Replacement: étape 8, image 1 de 1
    • Battery will be free to be removed and replaced.
10 autres ont terminé cette réparation.
Noah Franklin
Membre depuis le 10/27/15
445 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Shastany Fall 2015 Membre de l'équipe UMass Dartmouth, Team 2-3, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G3
3 membres
10 tutoriels rédigés
3 commentaires
Where can I get a replacement battery?
Jeremy Nocek - Réponse
You can look on Ebay or Amazon. You can find it by searching the model number: ( FT603048P )
The costs are like $20-$30.
If you look on Ebay under: ( 3.7v 603048 ), you can get the same battery without the connector for like $5.
William Smith - Réponse
hey i have a question, how i can repair the mute button? It does not work.
fiercecesar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 38
Total : 23,709
