Aller au contenu principal
Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement
Ce dont vous avez besoin
  1. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement, Adapter Audio Jack Board: étape 1, image 1 de 1
    • Wedge the Plastic Opening Tool below the plug and between the bottom plate and the body.
    • Leave the Plastic Opening Tool in place until the bottom piece is completely removed.
  2. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 2, image 1 de 3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 2, image 2 de 3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Spudger
    $2.99
    J'achète
    • Be firm but controlled with the Spudger. Excessive force may cause tool marks or crack the plastic causing structural damage.
    • The clips on the inside of the bottom cover that attach to the bottom of the device may make removal difficult. Be patient and work slowly.
    • Wedge the Spudger at an upward angle in between the two pieces of plastic above the audio jack. Be careful, this may take a firm push.
    • Gently point the Spudger at a downward angle into the gap between the bottom cover and the rest of the device. Take care to work the Spudger all the way in between the pieces when doing so.
    • Use the Spudger as a lever to gently pop the bottom cover over the lip of the audio jack.
  3. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 3, image 1 de 1
    T5 Torx Screwdriver
    $5.49
    J'achète
    • Unscrew the two T5 Torx head screws found on either side of the input for the controller. These screws are silver and 7.75mm in length.
    • Unscrew the three smaller black T5 Torx head screws. These screws are only 5mm in length and found around the perimeter of the input controller.
  4. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 4, image 1 de 3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 4, image 2 de 3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 4, image 3 de 3
    Metal Spudger Set
    $7.99
    J'achète
    • Handle with care. The wires and the traces on the circuit board break easily.
    • Insert the sharp end of the Metal Spudger in between the male and the female ends of the nine pin connector and slowly work the ends apart.
  5. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: étape 5, image 1 de 1
    Phillips #0 Screwdriver
    $5.49
    J'achète
    • Remove the two Phillips #0 head screws on either side of the Audio Jack board. These screws are 5.5 mm in length.
    • Remove the Audio Jack Board.
Manuel Zavala
Membre depuis le 01/31/15
117 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-36, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 membres
12 tutoriels rédigés
Un commentaire
Where do you get the replacement board??
Great write up, but no idea where to get the board.
Globe Spy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 1,900
