Introduction
This guide will teach you how to remove the side plate from the headset. You can use a metal spudger or your fingernail to remove the side plate. If you decide to use your fingernail, be warned that it will be a bit more difficult.
Ce dont vous avez besoin
Find the small notch on the side (left or right) of the side plate.
Insert the metal spudger into the notch.
Apply a gentle pressure outward so that the side plate will pop off.
To put the side plate back, simply snap the side plate into place.
