Aller au contenu principal
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
Ce dont vous avez besoin
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: étape 1, image 1 de 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: étape 1, image 2 de 2
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: étape 2, image 1 de 2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: étape 2, image 2 de 2
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
4 autres ont terminé cette réparation.
Nancy Truong
Membre depuis le 01/30/15
375 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-36, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 membres
12 tutoriels rédigés
7 commentaires
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - Réponse
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Commandcorps - Réponse
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 24
Total : 4,298
