Aller au contenu principal
Turtle Beach Elite 800 Audio Board Replacement
Ce dont vous avez besoin
  1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: étape 1, image 1 de 2 Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: étape 1, image 2 de 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: étape 2, image 1 de 2 Turtle Beach Elite 800 Audio Board Replacement, Audio Board: étape 2, image 2 de 2
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Audio Board Replacement: étape 3, image 1 de 2 Turtle Beach Elite 800 Audio Board Replacement: étape 3, image 2 de 2
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Audio Board Replacement: étape 4, image 1 de 3 Turtle Beach Elite 800 Audio Board Replacement: étape 4, image 2 de 3 Turtle Beach Elite 800 Audio Board Replacement: étape 4, image 3 de 3
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
2 autres ont terminé cette réparation.
Johnny Lofton
Membre depuis le 01/18/17
861 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 5
Total : 1,906
