Aller au contenu principal
Turtle Beach Elite 800 Battery Replacement
Ce dont vous avez besoin
  1. Turtle Beach Elite 800 Battery Replacement, Ear Cushion: étape 1, image 1 de 2 Turtle Beach Elite 800 Battery Replacement, Ear Cushion: étape 1, image 2 de 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Battery Replacement, Audio Board: étape 2, image 1 de 2 Turtle Beach Elite 800 Battery Replacement, Audio Board: étape 2, image 2 de 2
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Battery Replacement: étape 3, image 1 de 2 Turtle Beach Elite 800 Battery Replacement: étape 3, image 2 de 2
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Battery Replacement: étape 4, image 1 de 3 Turtle Beach Elite 800 Battery Replacement: étape 4, image 2 de 3 Turtle Beach Elite 800 Battery Replacement: étape 4, image 3 de 3
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
  5. Turtle Beach Elite 800 Battery Replacement, Battery: étape 5, image 1 de 3 Turtle Beach Elite 800 Battery Replacement, Battery: étape 5, image 2 de 3 Turtle Beach Elite 800 Battery Replacement, Battery: étape 5, image 3 de 3
    • Remove the battery by carefully prying it from the headset.
13 autres ont terminé cette réparation.
Johnny Lofton
Membre depuis le 01/18/17
861 Réputation
5 tutoriels rédigés
Équipe
55 commentaires
So there are two batteries in this headset that need to be replaced?
Doug Green - Réponse
Also, what battery do I purchase and does anyone know a good source to purchase them?
Max battery size: 50x36x9mm
Origina battery: 40x30x8mm
The pcm board can be replacement by old battery module.
Dariusz Fukiet - Réponse
Only one battery inside. Not sure why this guide takes appart the whole headset.
All steps&pictures related to right side (step 1, 2 and 4) are misleading and unnecessary when doing just battery replacement.
I ordered replacement on aliexpress.
joze_markic_bf - Réponse
What part number please and thank you in advance
jon fystro -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 37
Total : 32,263
