Aller au contenu principal
Turtle Beach Elite 800 Charging Pins on Headset Replacement
Ce dont vous avez besoin
  1. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: étape 1, image 1 de 2 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: étape 1, image 2 de 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: étape 2, image 1 de 2 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: étape 2, image 2 de 2
    • Use the Phillips #0 screw bit to remove the four screws (9.47 mm long) that have been revealed from removing the ear cup. Carefully take off the blue casing to reveal the audio board.
  3. Turtle Beach Elite 800 Charging Pins on Headset Replacement: étape 3, image 1 de 3 Turtle Beach Elite 800 Charging Pins on Headset Replacement: étape 3, image 2 de 3 Turtle Beach Elite 800 Charging Pins on Headset Replacement: étape 3, image 3 de 3
    • Use the Phillips #00 screw bit to remove the two screws (7.92 mm long) that are holding the contact pins in place.
    • Then, simply push the pins from the board.
Johnny Lofton
Membre depuis le 01/18/17
861 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 936
