Introduction
This guide is designed to help you replace the shoulder buttons on your REACT-R, which is critical for performing specific actions in many games. If your shoulder buttons are sticky, unresponsive, or have stopped working altogether, a replacement might be necessary to restore optimal functionality.
Follow these step-by-step instructions to replace the shoulder buttons and ensure your controller performs like new again. You'll need a Phillips #00 screwdriver for this task.
Ce dont vous avez besoin
Position the controller face down so that you're viewing its underside.
Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
Use both hands to lift the backplate away from the controller.
Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
Gently lift the motherboard up and out of the chassis.
The right and left bumper is attached to the face plate by two 9.2 mm Phillips screws.
Use a Phillips 00 screwdriver to remove each screw.
Gently remove each bumper from the faceplate.
