Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Two-Hole Button Replacement
Ce dont vous avez besoin
  1. Two-Hole Button Replacement, Two-Hole Button: étape 1, image 1 de 1
    • Choose a thread that will match the rest of the buttons on the jacket/button.
    Demander à FixBot
    Ajouter un commentaire
  2. Two-Hole Button Replacement: étape 2, image 1 de 1
    • Thread the needle so that there is equal thread on both sides of the needle.
    Demander à FixBot
  3. Two-Hole Button Replacement: étape 3, image 1 de 2 Two-Hole Button Replacement: étape 3, image 2 de 2
    • Tie a knot at the end of the thread so that it will not come back through the buttonhole.
    Demander à FixBot
  4. Two-Hole Button Replacement: étape 4, image 1 de 1
    • Place the button on the fabric that you are sewing it back on to.
    Demander à FixBot
  5. Two-Hole Button Replacement: étape 5, image 1 de 2 Two-Hole Button Replacement: étape 5, image 2 de 2
    • Take the threaded needle and push it through the fabric and one of the buttonholes on the bottom side and pull it through.
    Demander à FixBot
  6. Two-Hole Button Replacement: étape 6, image 1 de 2 Two-Hole Button Replacement: étape 6, image 2 de 2
    • Thread the needle down through the second hole of the button.
    Demander à FixBot
  7. Two-Hole Button Replacement: étape 7, image 1 de 1
    • Place a straight pin on the backside of the button to keep the button from being sewn on too tight.
    Demander à FixBot
  8. Two-Hole Button Replacement: étape 8, image 1 de 2 Two-Hole Button Replacement: étape 8, image 2 de 2
    • Repeat steps 5-6 to continue sewing the button on until secure.
    Demander à FixBot
  9. Two-Hole Button Replacement: étape 9, image 1 de 2 Two-Hole Button Replacement: étape 9, image 2 de 2
    • Once the button is secure, push the needle through the fabric but not the button and remove the pin.
    Demander à FixBot
  10. Two-Hole Button Replacement: étape 10, image 1 de 2 Two-Hole Button Replacement: étape 10, image 2 de 2
    • Once the pin is removed, wrap the thread around the button 6-7 times and push the needle through the fabric on the underside of the button.
    Demander à FixBot
  11. Two-Hole Button Replacement: étape 11, image 1 de 3 Two-Hole Button Replacement: étape 11, image 2 de 3 Two-Hole Button Replacement: étape 11, image 3 de 3
    • To finish sewing, make 3-4 stitches to tie off.
    Demander à FixBot
  12. Two-Hole Button Replacement: étape 12, image 1 de 3 Two-Hole Button Replacement: étape 12, image 2 de 3 Two-Hole Button Replacement: étape 12, image 3 de 3
    • Cut the remaining thread off.
    Demander à FixBot
Test out your fix by closing the jacket/clothing item with your resewn button!
Hannah Radtke
Membre depuis le 10/05/23
205 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 57
Total : 640
