Introduction
The micro-USB port is located under a rubber cover on the bottom of the UE Boom 2 speaker. Replacing this part requires the removal of the D-ring and rubber port cover, In addition the bottom pad must be removed, which will void the device warranty.
Pièces
Aucune pièce nécessaire.
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
  • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
  • Remove by twisting in a counter-clockwise motion.
Ajouter un commentaire
After the D-ring has been removed, the rubber port cover can be removed.
  • After the D-ring has been removed, the rubber port cover can be removed.
  • Remove the rubber stripping using a metal spudger.
  • Work around the edge of the rubber stripping slowly prying up the edge.
  • Continue removing the rubber stripping down the side.
  • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
  • Pry up at the location marked, and remove the plastic end cap.
  • The white plastic section houses the USB micro B, and must be replaced as a whole.
Alex Bahm
Membre depuis le 18/01/2018
1 187 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S12-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
3 membres
13 tutoriels rédigés
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Réponse
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 82
Total : 372
