Aller au contenu principal
UTStarcom XV6700 Motherboard Replacement
Ce dont vous avez besoin
  1. UTStarcom XV6700 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Motherboard Replacement: étape 3, image 1 de 3 UTStarcom XV6700 Motherboard Replacement: étape 3, image 2 de 3 UTStarcom XV6700 Motherboard Replacement: étape 3, image 3 de 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
  4. UTStarcom XV6700 Motherboard Replacement, Camera: étape 4, image 1 de 1
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
  5. UTStarcom XV6700 Motherboard Replacement: étape 5, image 1 de 2 UTStarcom XV6700 Motherboard Replacement: étape 5, image 2 de 2
    • Use firm pressure to carefully pry off the cover with your fingers.
  6. UTStarcom XV6700 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
  7. UTStarcom XV6700 Motherboard Replacement: étape 7, image 1 de 1
    • Gently pry off the camera flash circuit board with the spudger.
  8. UTStarcom XV6700 Motherboard Replacement: étape 8, image 1 de 1
    • Gently pry off the camera with the spudger.
  9. UTStarcom XV6700 Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
  10. UTStarcom XV6700 Motherboard Replacement: étape 10, image 1 de 1
    • Remove the 4.0-mm #00 Phillips screw that holds the antenna in place. The antenna does not need to be removed.
  11. UTStarcom XV6700 Motherboard Replacement: étape 11, image 1 de 3 UTStarcom XV6700 Motherboard Replacement: étape 11, image 2 de 3 UTStarcom XV6700 Motherboard Replacement: étape 11, image 3 de 3
    • Use the spudger or plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
    • Carefully pry the black portion of the case away from the silver portion.
    • Do not try to remove the case completely. The speaker wire is still connected to the motherboard.
  12. UTStarcom XV6700 Motherboard Replacement: étape 12, image 1 de 1
    • Using tweezers, pull with gentle pressure in the direction of the wire to unplug from the motherboard connector.
  13. UTStarcom XV6700 Motherboard Replacement: étape 13, image 1 de 1
    • Remove the 4.0-mm #00 Phillips screw holding the motherboard in place. The screw is in the middle of the motherboard, near the outside edge.
  14. UTStarcom XV6700 Motherboard Replacement: étape 14, image 1 de 2 UTStarcom XV6700 Motherboard Replacement: étape 14, image 2 de 2
    • With your fingers, disconnect the keyboard cable from the motherboard. The cable is orange with the letters T/B printed on the connector.
  15. UTStarcom XV6700 Motherboard Replacement: étape 15, image 1 de 2 UTStarcom XV6700 Motherboard Replacement: étape 15, image 2 de 2
    • Carefully lift up on the motherboard with the spudger until you can see the display cable connected to the underside of the motherboard. The display cable connector will be taped over.
  16. UTStarcom XV6700 Motherboard Replacement: étape 16, image 1 de 1
    • Use the spudger to peel away the tape from the connector.
  17. UTStarcom XV6700 Motherboard Replacement: étape 17, image 1 de 1
    • Using the spudger, pry away the display cable connector from the motherboard. The motherboard is now completely disconnected.
Jesse Walker
Membre depuis le 06/04/13
201 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 368
