Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME, utilisez notre manuel de réparation.
    1. Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Cover removal: étape 1, image 1 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Cover removal: étape 1, image 2 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Cover removal: étape 1, image 3 de 3
      • Remove the two rubber adhesive strips to uncover the four screw holes
      • Remove the four small screws and lift the cover.
      Demander à FixBot
      Ajouter un commentaire
    2. Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 1: étape 2, image 1 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 1: étape 2, image 2 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 1: étape 2, image 3 de 3
      • The main board is now visible.
      • Remove the four screws
      • Unplug the two highlighed connectors
      • First connector, on the left in the picture, for the leds, microphone, speaker
      • Second connector, on the right in the picture, for the ethernet port
      • You can now gently lift the main board, passing the two cables that you unplugged through their respective holes on the board. There will be a bit of resistance as there is a chip with thermal paste that adheres to the underlying metal cover
      Demander à FixBot
    3. Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 2: étape 3, image 1 de 1
      • Remove the cable connected to the bottom of the main board
      • This cable is connected to the camera
      Demander à FixBot
    4. Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 3: étape 4, image 1 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 3: étape 4, image 2 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Main board removal 3: étape 4, image 3 de 3
      • You can now remove the main board
      • I cleaned the chip from the thermal paste to reveal that it is an Ambarella S5L IP Camera SoC (full code: Ambarella S5LM-A0-RH A2114 SD8P7-2N3 1N1 S5L55M)
      Demander à FixBot
    5. Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Remove rotating disc: étape 5, image 1 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Remove rotating disc: étape 5, image 2 de 3 Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Remove rotating disc: étape 5, image 3 de 3
      • Remove the two screws on the sides of the rotating disc
      • You can now remove the rotating disc that includes the ethernet connector (here pictured from below)
      • You have now access to the main body with the camera, the microphone, the speakers and the leds
      Demander à FixBot
    6. Ubiquiti UniFi Protect G4 Dome Camera UVC-G4-DOME Teardown, Full teardown: étape 6, image 1 de 1
      • Insert wisdom here.
      Demander à FixBot
Giulio Marcon
Membre depuis le 05/11/21
385 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 88
Total : 1,397
