Introduction
Since batteries are often the first component to fail due to charging cycles and age, this guide is crucial for extending the life of the device. This guide will demonstrate how to safely remove and replace the battery in the Ultimate Ears Wonderboom 3.
Before using this guide, it is important to note that this repair may affect the speaker's ability to be waterproof. Make sure the speaker is powered off.
Ce dont vous avez besoin
To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
Unscrew the four M3 x 6mm Phillips head screws in each corner of the speaker.
Locate and unscrew the M3 x 8mm screws found under each of the four speakers.
Remove the main center of the speaker, exposing the bottom and the battery.
Carefully place the metal spudger under the battery. Being slow yet forceful, push the spudger under the battery and force upwards. This will pry the waterproof adhesive, affecting its ability to be waterproof in the future.
Remove the battery from the adhesive and set it aside.
