Introduction
Use this guide if you are experiencing a decline in audio quality in your Wonderboom 3 speaker. This guide will instruct you on how to replace the speaker drivers, which are critical for sound output. Over time or due to mishandling, these drivers can fail or degrade.
Before using this guide, it is important to note that this repair may affect the speaker's ability to be waterproof. Make sure the speaker is powered off.
Ce dont vous avez besoin
To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
Unscrew the four M3 x 6mm Phillips head screws in each corner of the speaker.
