Aller au contenu principal
Unbranded UB-15MS10 Battery Replacement
Ce dont vous avez besoin
  1. Unbranded UB-15MS10 Battery Replacement, Battery: étape 1, image 1 de 1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Battery Replacement: étape 2, image 1 de 1
    • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
  3. Unbranded UB-15MS10 Battery Replacement: étape 3, image 1 de 2 Unbranded UB-15MS10 Battery Replacement: étape 3, image 2 de 2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Battery Replacement: étape 4, image 1 de 1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Battery Replacement: étape 5, image 1 de 1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Battery Replacement: étape 6, image 1 de 1
    • Cut the wires connecting the battery to the device using a pair of wire cutters.
  7. Unbranded UB-15MS10 Battery Replacement: étape 7, image 1 de 1
    • Carefully remove the battery, making sure that all wires are disconnected.
  8. Unbranded UB-15MS10 Battery Replacement: étape 8, image 1 de 1
    • Splice the new battery with the red, white, and black wires connected to the motherboard.
To reassemble your device, follow directions 1-7 in reverse order.
3 autres ont terminé cette réparation.
Evan Peterson
Membre depuis le 03/08/17
320 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S5-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G5
3 membres
4 tutoriels rédigés
Un commentaire
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 2,307
