Aller au contenu principal
Uniden EXP 371 Charging Contact Points Replacement
Ce dont vous avez besoin
  1. Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: étape 1, image 1 de 2 Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: étape 1, image 2 de 2
    • Your first step will be to remove the battery cover and the battery.
  2. Uniden EXP 371 Charging Contact Points Replacement: étape 2, image 1 de 1
    • The next step will be to remove the two screws from the rear of the phone case.
  3. Uniden EXP 371 Charging Contact Points Replacement: étape 3, image 1 de 1
    • After that you will need to pry the back of the case off of the front part of the case.
  4. Uniden EXP 371 Charging Contact Points Replacement: étape 4, image 1 de 2 Uniden EXP 371 Charging Contact Points Replacement: étape 4, image 2 de 2
    • After removing the rear cover there will be two more screws to remove that hold each of the charging contact points. Once those are removed you can replace them with the new ones.
    • When replacing the charging contacts, they only go on one way, but it is useful to note how the original ones were on.
    • Reverse these steps in order to reassemble your phone.
Eric Rodrigues
Membre depuis le 10/16/14
343 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 143
