Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
If problems occur with the button keypad, this guide will show the user how to thoroughly clean them.
  1. Starting from the top of the cover, slide down and away from the phone with your thumb Lift battery cover off of batter and place it to the side
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone) Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Ensure that wired connection between circuit board and back shell is not strained Fold the back shell underneath the front shell and circuit board Fold the back shell underneath the front shell and circuit board
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Using index finger and thumb, carefully remove the circuit board from the front shell of phone Using index finger and thumb, carefully remove the circuit board from the front shell of phone Using index finger and thumb, carefully remove the circuit board from the front shell of phone
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
  8. Remove the white plastic sheet covering the button pad with your fingers Gently remove the silicon button pad Gently remove the silicon button pad
    • Remove the white plastic sheet covering the button pad with your fingers
    • Gently remove the silicon button pad
  9. Wet one end of the cotton swab with water and clean button pad as needed Repeat process with multiple cotton swabs if needed
    • Wet one end of the cotton swab with water and clean button pad as needed
    • Repeat process with multiple cotton swabs if needed
    • Dry the button pad with a clean, soft rag before replacing
Gary Pence
Membre depuis le 26/03/2014
807 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 1-1, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 720
