Aller au contenu principal
Uniden TCX905 Circuit Board Replacement
Ce dont vous avez besoin
  1. Uniden TCX905 Circuit Board Replacement, Battery Cover: étape 1, image 1 de 2 Uniden TCX905 Circuit Board Replacement, Battery Cover: étape 1, image 2 de 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Circuit Board Replacement, Battery Pack: étape 2, image 1 de 2 Uniden TCX905 Circuit Board Replacement, Battery Pack: étape 2, image 2 de 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Circuit Board Replacement, Back Shell: étape 3, image 1 de 2 Uniden TCX905 Circuit Board Replacement, Back Shell: étape 3, image 2 de 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Circuit Board Replacement: étape 4, image 1 de 3 Uniden TCX905 Circuit Board Replacement: étape 4, image 2 de 3 Uniden TCX905 Circuit Board Replacement: étape 4, image 3 de 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Circuit Board Replacement: étape 5, image 1 de 3 Uniden TCX905 Circuit Board Replacement: étape 5, image 2 de 3 Uniden TCX905 Circuit Board Replacement: étape 5, image 3 de 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Circuit Board Replacement, Circuit Board: étape 6, image 1 de 2 Uniden TCX905 Circuit Board Replacement, Circuit Board: étape 6, image 2 de 2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Circuit Board Replacement: étape 7, image 1 de 3 Uniden TCX905 Circuit Board Replacement: étape 7, image 2 de 3 Uniden TCX905 Circuit Board Replacement: étape 7, image 3 de 3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
Gary Pence
Membre depuis le 03/26/14
807 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 1-1, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 membres
16 tutoriels rédigés
2 commentaires
I liveI at Buenos Aires, Argentina. I need to repaire a Uniden TCX905 Circuit Board and I wish to receive the manual for repaire, if it existe. Thanks in advance . Ruben E. (zrubene@gmail.com)
zrubene - Réponse
Where can one get a TCX905 replacement circuit board?
greywing - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 905
