Aller au contenu principal
Unsticking Steelseries Nimbus Triggers
Ce dont vous avez besoin
  1. Unsticking Steelseries Nimbus Triggers, Unsticking Steelseries Nimbus Triggers: étape 1, image 1 de 1
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking Steelseries Nimbus Triggers: étape 2, image 1 de 2 Unsticking Steelseries Nimbus Triggers: étape 2, image 2 de 2
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking Steelseries Nimbus Triggers: étape 3, image 1 de 3 Unsticking Steelseries Nimbus Triggers: étape 3, image 2 de 3 Unsticking Steelseries Nimbus Triggers: étape 3, image 3 de 3
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking Steelseries Nimbus Triggers: étape 4, image 1 de 2 Unsticking Steelseries Nimbus Triggers: étape 4, image 2 de 2
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking Steelseries Nimbus Triggers: étape 5, image 1 de 3 Unsticking Steelseries Nimbus Triggers: étape 5, image 2 de 3 Unsticking Steelseries Nimbus Triggers: étape 5, image 3 de 3
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking Steelseries Nimbus Triggers: étape 6, image 1 de 3 Unsticking Steelseries Nimbus Triggers: étape 6, image 2 de 3 Unsticking Steelseries Nimbus Triggers: étape 6, image 3 de 3
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking Steelseries Nimbus Triggers: étape 7, image 1 de 2 Unsticking Steelseries Nimbus Triggers: étape 7, image 2 de 2
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
7 autres ont terminé cette réparation.
Jonathan
Membre depuis le 03/13/13
428 Réputation
2 tutoriels rédigés
4 commentaires
Great, concise fix instructions!
Brian Pippen - Réponse
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - Réponse
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - Réponse
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 76
Total : 5,404
