Aller au contenu principal
Untracked Bifold Door Pin Replacement
Ce dont vous avez besoin
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: étape 1, image 1 de 1
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: étape 2, image 1 de 1
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: étape 3, image 1 de 1
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: étape 4, image 1 de 2 Untracked Bifold Door Pin Replacement: étape 4, image 2 de 2
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: étape 5, image 1 de 1
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: étape 6, image 1 de 1
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: étape 7, image 1 de 1
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: étape 8, image 1 de 1
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: étape 9, image 1 de 1
    • When completed, the bifold doors should close and be positioned within the tracking.
Catelyn Carpenter
Membre depuis le 01/16/20
169 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 49
Total : 1,397
