Introduction
There is no visible way to open this device. Knowing this, assembly and disassembly must be done carefully in order to maintain the integrity of the device.
Ce dont vous avez besoin
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Presque terminé !
