Aller au contenu principal
VTech Baby's Learning Laptop LEDs Replacement
Ce dont vous avez besoin
  1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: étape 1, image 1 de 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop LEDs Replacement: étape 2, image 1 de 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop LEDs Replacement: étape 3, image 1 de 2 VTech Baby's Learning Laptop LEDs Replacement: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
  4. VTech Baby's Learning Laptop LEDs Replacement: étape 4, image 1 de 3 VTech Baby's Learning Laptop LEDs Replacement: étape 4, image 2 de 3 VTech Baby's Learning Laptop LEDs Replacement: étape 4, image 3 de 3
    • With the lid closed, position the device such that the handle is pointing towards you.
    • Using your fingers, gently pry open the cover from the hinge.
    • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
  5. VTech Baby's Learning Laptop LEDs Replacement: étape 5, image 1 de 1
    • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
  6. VTech Baby's Learning Laptop LEDs Replacement: étape 6, image 1 de 1
    • Pickup the array by the opening in the center of the board.
    • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
    • Movement of the array will be limited as it is still attached to the main device board.
Équipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 15
Total : 920
