Aller au contenu principal
VTech Baby's Learning Laptop Speaker Replacement
Ce dont vous avez besoin
  1. VTech Baby's Learning Laptop Speaker Replacement, Battery and Rear Panel: étape 1, image 1 de 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Speaker Replacement: étape 2, image 1 de 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Speaker Replacement: étape 3, image 1 de 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Speaker Replacement: étape 4, image 1 de 2 VTech Baby's Learning Laptop Speaker Replacement: étape 4, image 2 de 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Speaker Replacement, Speaker: étape 5, image 1 de 2 VTech Baby's Learning Laptop Speaker Replacement, Speaker: étape 5, image 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
  6. VTech Baby's Learning Laptop Speaker Replacement: étape 6, image 1 de 2 VTech Baby's Learning Laptop Speaker Replacement: étape 6, image 2 de 2
    • Remove the two 6 mm screws from the device.
    • Remove the speaker.
    • Be careful not to damage the wiring.
Jordan Smith
Membre depuis le 09/03/15
210 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 membres
14 tutoriels rédigés
2 commentaires
Where to buy the replacement speaker
hadbuckley - Réponse
Where can you buy the replacement speaker please. I live in Sydney Australia
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 23
Total : 1,239
