Introduction
During this guide, the back of the phone will need to be taken off to access the speaker and wires. You will need to use the tweezers to remove the metal “U” shaped clip holding the speaker to the back cover.
Ce dont vous avez besoin
Push down on the battery cover in the direction of the arrow located on the back of the phone.
Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
Refer to How To Solder and Desolder Connections Comment souder et dessouder des connexions
2 commentaires
Where can I buy the speaker for the phone?
